Trans Oil
What's with these Sears guys - $6 for a single torx?
You can get a set of 13 including T27 for $16
http://www.amazon.com/Neiko-10071A-P.../dp/B000J0TF6G
And, by the way, this might be useful for identifying/ordering gaskets & seals which they recommend you change
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
http://partsfinder.onlinemicrofiche....USTOM-%28CT%29
And so are other model years... I checked 2010, 2011
My 2012 Sportster is in there... the whole Sportster line
Problem is, if you already have all the other sizes, you might still come up ahead if you buy just what you are missing.
+1 - Torx bits are one tool that you don't want to scrimp on quality wise. The cheaper ones are typically made from a softer metal and you'll wind up with stripped bits and screw heads.
I read some where that HD has switch to yet another fastener type called torx+ which can be removed with the old style torx drivers but you run a greater risk of strip out. I have not seen the torx+ drivers anywhere. I haven't checked with the HD shop where, if they have them I am sure would be made of gold or so priced.
They are supposed to have a greater land area at the tips of the "star" to increase torque transfer and reduce stripping.
Anyone know anything about them?
I'd really like to see a list of fasteners on a Harley. Anyone got one?
The service manual has torque specs for just about every fastener. But it doesn't say what that fastener is. Would be nice, if someone was going to be a DIY, if we had a inventory of the fasteners. Harley should provide that - they show me every part int the "parts finder" - just tell me that that inspection cover fastener is a Torx T27. Then I have my "shopping list" for DIY tools.
I have yet to see Torx+ on a stock bike but then I don't work on too many bikes.
On a side note, after buying a metric bike and being able to work on it with just a single metric set of sockets, I hate how Harley switches between SAE and Metric and then on some parts like the front calipers uses 12 point bolts. Seriously pisses me off working on the Sporty now having to go back and forth.
I would like to see a list of all the different type of fasteners.
I think it would probably run the gamut of all the bolt/screws in existence:sae, metric, torx, allen, phillips, flat, and on and on...
Oh well, I guess thats what makes it a HD>Hard to Diy.
Even though, they are not that hard to work on, just hard to have all the correct tools.
PS I hope they never switch the intake allens to torx. It would be hard to saw the end off a torx and have enough left of the star to use.
