1980 sporster ?
1980 sporster ?
i just picked up a 1980 sporster yesterday if fires right up sounds good, i live around detroit so i couldn't take it for a ride so i over looked the clutch but any way got it home and it seams the clutch isn't engageing i was told it has a brand new clutch in it any sugestions why it might not be working. i tryed to put more tention on the cable and still nothing. any help apreciated, i am new to the harley
RE: 1980 sporster ?
..could be several factors,,like cable not sliding do to corosion,
did it move any at all???did it pull 1/4 way then stick in??
but first look the condition of cabel over,if your lucky thats
what it is,,try lubication of cable first,,good luck,could be clucth
locked up,,lots of things it could be,,
RE: 1980 sporster ?
Isn't is supposed to have 90 weight oil? Maybe I'm wrong, I'll have to check my manual. If you live in MI, then it was probably cold, so any oil would be cold and that would cause it to be thicker than in a warm environment. So sure, after it warms up it would thin out. I don't ever have a problem with that on my 83 Sportster, and I used to live in MI as well.
My manual says that the transmission takes 1.5 pints of Power Blend Super Premium Oil...what ever that is. That's for 79-early 84 Sportsters. It doesn't say anything about clutch oil that I can see yet. Here is what else it says:
Type - wet-multiple disc
Capacity - 174 ft-lbs
Sprint
adjustment - fixed spacers std. length 1.530 in.
free length inner - 2-25/64 in.
free length outer - 2-25/64 in.
Clutch shell bearing on clutch gear (loose) - .0000 in. - .0010 in.
I have not had to work on my clutch or transmission yet, but maybe they share the same oil?
[IMG]local://upfiles/23810/62B58C126DBE46C482DBF44907FB3408.jpg[/IMG]
Sprint
RE: 1980 sporster ?
Isn't is supposed to have 90 weight oil?....My manual says that the transmission takes 1.5 pints of Power Blend Super Premium Oil...what ever that is....That's for 79-early 84 Sportsters. It doesn't say anything about clutch oil that I can see yet. I have not had to work on my clutch or transmission yet, but maybe they share the same oil?...
RE: 1980 sporster ?
ORIGINAL: bubba_d_duck
the cables good i put tention on the cable and pulled the clutch in and could hear a pop so i guess its some thing in side. knowing my luck i will have to replace the clutch
ronyd
03-19-2008 10:39 AM
