10" bars, need new lines?
I bought some 10" Nash Midget Gimps solely because Nash stated in their advertising that it would not require longer lines.
I haven't received them yet, I should tomorrow or in the next couple of days, but I read about a guy installing 8" bars and said his clutch line was pretty tight and for anything taller would need a longer line.
So crap. These are ten inch.
Do any of you know? This is for a 2010 Iron.
How about the wiring for the controls, will they need extended too?
I have 10" zbars on my 48 (not sure if nightster cables are any different) but only cable that needed for sure changing was the brake line and your control wires may require some adjustment moving some zip tires around to get some slack. I went ahead and purchased all new cables for the look and quality of upgraded lines but they seemed to be much longer than needed but gives you peace of mind...hope this helps
magnum shielding has a build your own cable kit. 6ft black stainless steel line. part # 496190A $55
http://www.magnumshielding.com/store...ines-black.php
I may check out the Burly but I doubt they are a better price.
I decided to post the bars up for sale if anyone is interested.
https://www.hdforums.com/forum/sport...get-gimps.html
This is right the only cable you should need to change is the Break line, i installed the 10" Z Bars and that is all i had to change on my nightster Cheers Mate
Finally got around to ordering this brake line and they are out of stock on all of the BYO BLK Brake Line Kit Single Disc 6' kits.
Bummer.
