Shorted the battery!
Old 08-13-2012 | 10:10 PM
el ricky's Avatar
el ricky
Default Shorted the battery!
I have a 2009 Nightster, and i was tightening up the battery back into place and accidently touched both poles of the battery with the wrench. Sparks flew and even created an arc similar to a welders arc. Melted the metal on the wrench. Needles to say the battery was dead after that. I checked the fuses and they seemed ok. i attempted to jump start the bike with my F150 but got nothing just clicking noise. I charged the battery overnight and lights turned on when turning the key on but only clicking noise when i attempt to turn it over. Has this happened to anyone? or Does anybody know where the problem lies? I am in the process of getting a new battery but dont know if that the only issue. Any help would be much appreciated. Thanks in advance.
Old 08-13-2012 | 10:29 PM
HOTLAP's Avatar
HOTLAP
Not sure if you would get lights on the dash with it blown but did you check the big BUSS fuse?
Old 08-13-2012 | 11:42 PM
Nubz's Avatar
Nubz
Actually you shorted nothing and completed a circuit
But **** the technical **** LOL
Might have blown a fuse or cooked the battery enough to kill it
Old 08-13-2012 | 11:51 PM
soft 02's Avatar
soft 02
Quick question. Was the truck running when you jumped the bike?
Old 08-14-2012 | 12:12 AM
Zenmervolt's Avatar
Zenmervolt
The clicking you're hearing is the starter solenoid. There's not enough power to run the starter but there's enough to trip the solenoid.
Check all the connections, that may be a bigger problem here if jumping from a car battery wasn't enough to spin the starter.
Old 08-14-2012 | 12:55 AM
el ricky's Avatar
el ricky
If you mean the big 30A one with a cover on it that is next to the battery, then yes. It looks good.
Old 08-14-2012 | 12:59 AM
el ricky's Avatar
el ricky
Lol! Learn something new every day. Two things on Sunday. I'll go over the fuses again tomorrow check for corrosion in the fuse box as well.
Old 08-14-2012 | 01:09 AM
el ricky's Avatar
el ricky
Yes it was on.
Old 08-14-2012 | 01:13 AM
el ricky's Avatar
el ricky
So what do u think it could be?
Old 08-14-2012 | 08:37 AM
GDixon61's Avatar
GDixon61
Have the Battery load tested after charging over night to learn if it is fried or ok.
Only way to be accurate and then it's time to get your handy dandy magic meter out to measure voltages if the Battery turns out to be ok.
Quick Reply: Shorted the battery!
