Death wobble 70+
Old 08-04-2012, 10:00 PM
John_K's Avatar
John_K
John_K is offline
Replace fork oil.
Old 08-05-2012, 05:53 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Wink
Originally Posted by Judge1989
About 1/4 inch difference. Wow, I'll make the adjustment and update. Thanks!
Having found the likely source of your problem, check wheel alignment between the two wheels. You can do that with patience by sight, or with a length of string pulled tight, or a long straight-edge such as a piece of straight pipe or length of straight timber.
Old 08-05-2012, 06:25 AM
xFreebirdx's Avatar
xFreebirdx
xFreebirdx is offline
there is a small hole on either side of the swing arm. Its about 12" - 16" from the axle. You measure from that hole to the center of the axle to adjust/square your axle. You can make or buy a tool like in the pic to adjust it.
Make sure to check your belt tension while your doing the adjustment.
Old 08-05-2012, 08:24 AM
RATROD HOG's Avatar
RATROD HOG
RATROD HOG is offline
are you still with us ?
i hope so.
Freebird good call there.
Old 08-06-2012, 07:26 AM
Mozvader's Avatar
Mozvader
Mozvader is offline
Received 1,184 Likes on 849 Posts
Bumpity Bump
Old 08-06-2012, 08:00 AM
1984_FXRT's Avatar
1984_FXRT
1984_FXRT is offline
Rear wheel alignment is critical - as others have said, the distance from the center of the axle to the hole in each side of the swingarm MUST be the same.
Another possible culprit on your bike is that the swingarm pivot bushings/bearings are worn. Elevate the rear of the bike so that the tire is off the ground, while having someone watch the swingarm pivot, have someone else grab the back wheel and try to move it side-to-side. Any side-to-side play is not good.
(there's a spec in the manual for this runout, but, if you can see it move, you've most likely exceeded this spec).
Old 08-06-2012, 10:37 AM
Judge1989's Avatar
Judge1989
Judge1989 is offline
Yes I am still with you guys. Thanks for checking in! Upon realizing what I did I sat at home yesterday with a beer and a dunce cap. I distinctly remember aligning the bike, and then tensioning the belt. Whoops... thanks gor the info everybody! Rides up to 90 like a vibrating dream now!
Old 08-06-2012, 10:46 AM
Thumper26's Avatar
Thumper26
Thumper26 is offline
Talking
That's what we like to hear!
Old 08-06-2012, 11:05 AM
Mozvader's Avatar
Mozvader
Mozvader is offline
Cheers...
Old 08-06-2012, 07:59 PM
bmxatv's Avatar
bmxatv
bmxatv is offline
^^^that thing!
well that's good to hear. don't forget if it happens next time pucker your hole and steer it home. lolol. glad to hear you aint dead yet....
Quick Reply: Death wobble 70+
