Is it possible to weld on ports of O2 sensors?
Old 08-02-2012 | 06:15 PM
thoner7's Avatar
thoner7
Default Is it possible to weld on ports of O2 sensors?
I may have a good deal on a used exhaust, but the problem is its for the 86-03 bikes. I have an 07 with the O2s.
I believe the only difference between them is the O2 ports (correct me if I am wrong, I may be thinking 04-06 are the only ones that are identical). What would stop me from drilling out a hole on the backside of the pipe and welding on a nut with the proper threads?
They are Bassani Sweepers. Any change its possible? What am I missing?
Old 08-02-2012 | 07:47 PM
Tripiii's Avatar
Tripiii
Yep just buy a set of O2 sensor bungs and weld them in. Just make sure you put them where you have room for them. I like mine pretty close to the stock location.
Old 08-02-2012 | 07:51 PM
TUCCI's Avatar
TUCCI
I was under the impression the bungs needed to be at a certain angle to work properly?
Iceman24's Avatar
Iceman24
Or...get yourself a tuner w/O2 bypass & then you're good for new exhaust + additional mods.
FYI, I'd "double-check" fitment on those '03 pipes...there were some design changes on 04+ bikes so they may look like they'd fit, but bend/angles could prove wrong...
Old 08-03-2012 | 08:05 PM
thoner7's Avatar
thoner7
Well I'm scratching that idea because I found this:
I need to convince the guy I'm not scamming him and get him to ship them to me, but I figured this is doable. any suggestions?
Old 08-04-2012 | 06:22 AM
Proteus's Avatar
Proteus
I'm toying with the same idea, as I want to put a 2-in-1 Paughco pipe set on my 2012 XLC, and there are no 02 bungs in them.
I stay tuned on this topic.
Old 08-04-2012 | 11:02 AM
Tripiii's Avatar
Tripiii
Here is a great video from ThunderMax on installing bungs. They need to be within 6" of the cylinder end of the header pipe.
Hope that helps
Old 08-04-2012 | 11:18 AM
tlb's Avatar
tlb
I had bungs welded in my Vance and Hines pipes. To get the angled ones, I had to order them from Zippers. I needed bungs for my ThunderMax system. The one difference between a set of Big shots for an 07 and new softail and a pre 06 is the bungs. I just took some pictures of the location on a newer set and marked my pipes. I took them to a muffler shop and had them welded in. It cost about 20 bucks. I do seem to remember you need to have the bung within something like 6 inches of the head.
RonnieC (04-11-2022)
Old 08-04-2012 | 11:38 AM
cHarley's Avatar
cHarley
+1 - The Sporty was completely redesigned from the frame up in 2004. If the pipes include a frame support bracket, you'll likely have to do some fab work to get them to fit.
Old 08-05-2012 | 11:28 AM
thoner7's Avatar
thoner7
Does anyone know if sideshots will hit the pavement during hard cornering? Thats why I'm getting rid of the slip ons, I bounce the lower muffler off the pavement and my rear and the rear end gets loose. I'm afraid one of these days I'm gonna loose control.
My other option are these but I like the sideshots more...assuming they wont hit pavement. http://www.spitfiremotorcycles.com/p...ortster-pipes/
Jeffrey Hatch
04-24-2019 10:27 PM
Road Star
Milwaukee Eight (M8)
08-31-2018 12:25 PM
leafman60
08-02-2016 07:54 PM
diamondheadglide
12-14-2007 08:07 AM
DFTL20
06-20-2006 12:06 AM
