New exhaust questions
The bike feels like it has a bit more torque and the sound is perfect. I only have about 30 miles on them but I will get back to you with an update when I put some more miles on.
That's normal for a bike without modified engine management, but is not good IMHO!
Stock bikes run very lean to meet EPA regulations, but as wanabe says even a stock bike will benefit from an ecu, to restore air/fuel ratios. It is not just a heat thing, the bike will run better all round, especially with a change of mufflers!
Our bikes are very refined beasties these days and backyard tuning is a thing of the past. We need to get smart!
I've been riding since the 60s and owned Harleys since the 70s. None of my bikes in over half a million miles have popped, unless something was wrong. It ain't 'normal' and yours ain't right!
Hi K9, your scoot looks very neat! Was planning to go for the same slips...are they the V&H 3" twin slashers? How much did ya pay for them?
I'm gonna get the chrome ones, but also looked up the black ceramic ones you have...the pics on the site do show shotgun style header covers, but they do state that the pics use OEM accessory header shields from HD, so you havent been gypped.
Could you post some close ups? Curious coz the website has pics that show a few mm of muffler stcking out from under the shields at the tail end, but dont see that in your pics. Read the installation manual and they show how that tail outta look after a proper install.
Much appreciated!
Much appreciated!
There is no performance increase with just putting on more open pipes. That is all in your mind from the sound.
The internal combustion is basically an air pump. Just because you open up the back side of the pump, there won't be any increase in performance until you take the sock out of the mouth, and adjust the fuel delivery system to compensate for the additional air.
http://www.motorcycle-usa.com/413/13...-Shootout.aspx
Vance & Hines said that some decel "popcorn" is normal when you're off the throttle at low speeds
The Dyno results from MotoUSA would beg to differ. Here is a link to the Slip-on Shootout article and the HP chart showing significant increases (up to 20%) from stock.
Yes, but those Dyno results weren't with bikes that had stock air cleaners. That is a comparison of different pipes. NO WAY you can get 20% increase without putting more air into the engine. You can find anything on the internet, but it doesn't change basic physics. If you can't put more air and more fuel into the engine, not much is going to change. If it did, why would so many of us change out air cleaners and fuel delivery systems??
