Z Bar Question
Z Bar Question
Thinking about ordering these:
http://www.ebay.com/itm/12-ape-hange...sories&vxp=mtr
This will be the first mod I've ever done on a bike but I know I have the resources to do it.
Is there anyone else who as installed these? If so did you have to order cable extenstions or could you use the stocks and just cut zip ties?
Also, im guessing I will need a new brake and clutch line? Where is the best place to order those?
Thanks for any help.
You'll definitely need to replace the brake line and extend the control wires.. And possibly the clutch cable. I just installed the licks 12" z bars (with some..a lot.. of help from a buddy) this past weekend. Start to finish probably took about 4 hours for some noobs. Best piece of advice I can give is to use a vacuum and a shoe string. Cover all the holes except for the crossbar hole and the end of one handlebar. Use the vacuum to suck the string through the bars. Then use the string to pull some mechanics wire through. Then attach and tape that wire to your control wires to pull/tug through. Good luck!
superglideRN
General Topics/Tech Tips
01-07-2015 05:48 PM
