Auto Meter 3209 with Hose Clamp?
Does anyone see a problem with mounting the Auto Meter 3209 with a hose clamp to a fork instead of the tank bolt? I just did the speedometer relocate along with the installing the new indicator light Joker Machine top clamp. The Auto Meter mount feels quite secure and sturdy on the fork mounted with a hose clamp inserted through the 2 slots of the Auto Meter base (the black part) then wrapped around the fork. Has anyone tried this mounting method? If this will work then it will save me from spending $159.95 on the Joker Machine speedo ring mount.
So, I decided to just simply go with the tank bolt mount option with my speedo relocate. I did place a 1/4 inch spacer behind the Auto Meter mount and the tank mount though. Here's the order from the tank mount outward using the tank bolt method: 1/4 inch spacer (I removed the original flat washer against the tank mount), Auto Meter mount with the outermost hole drilled using a 19/64 twist drill bit, split washer, nylon locking nut. I just got back from taking her for a spin. What an improvement in visibility past the bars! I wouldn't have attempted this project so easily if it weren't for all the information from this forum. Thanks to everyone here!
