tank lift dk custom
tank lift dk custom
Did anyone else do this tank lift from.dk.customs and if i do a 2" on my 1200 custom will I loose fuel capacity....why does jp cycle sell their tank kit with what looks like fuel lines???? Mr dj custom.s doesnt say if I need fuel lines or not. Sorry i using my phone to type this all out.
I did a 2 1/2 inch lift on my nightster and have no issues. Same amount of range as always. But I go by miles not the light. If your looking for a lift go with dk and if your worried about the fuel lines. Loosen the rear tank bolt. Remove the front and slowly lift it two inches and take a look around.
I did a two inch tank lift with some brackets I picked up from Lowes. I didn't need new fuel lines and the only thing that was affected was the range I get now. It is a little less because the fuel tank sits at a steeper angle and that affects the reading for the gas light.
I usually stop at 150 miles. And top off. I hope I can still do that. As I go on rides I don't wanna be that guy who has to stop all the time before everyone else. Lol
Received 4,221 Likes
Some models need a long fuel line, others need a longer fuel line and vacuum line. The Sportster does not need either.
With a 2" you will lose about 5-10 miles in range. However, unless you run your tank dry right now, you will never see that in your riding experience. (you will just have a little more fuel still in your tank when you fill up).
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
