2003 1200 Crank no Start
Hi there, trying to help my Dad diag his sporty here are the symptoms:
Intermittent dying and no start. Today it finally didn't start while I was around it and I checked a couple things I could think of. Coil primary and secondary resistance was in spec, attempted to start with test light on coil terminals and test light slightly dimmed and I was thinking it should flash..
Leaning toward the ignition module as from what I've read it's a very common problem for the nose cone mounted units. I've found a nice looking ultima unit from Jireh for about 105.
Is there anything else I should check before we order a module? We've wiggle tested almost everything we could get our hands on with no luck.
Thanks
Thanks
Thanks
Thanks
Traffanstead
Engine Mechanical Topics
08-01-2015 02:44 PM
