Plate relocation - how?
Old 07-29-2012, 07:18 PM
USMCDevilDogg's Avatar
USMCDevilDogg
USMCDevilDogg is offline
Originally Posted by emperor wurm
cut your belt guard.
I did the same thing...looks good and affordable
  #32
Old 07-29-2012, 07:26 PM
mrmikey32's Avatar
mrmikey32
mrmikey32 is offline
Originally Posted by mhenry
What about lighting it up any one have problems with police on this issue
http://www.ebay.com/itm/Universal-LE...r#ht_724wt_905
  #33
Old 07-29-2012, 07:46 PM
laffin gas's Avatar
laffin gas
laffin gas is offline
http://www.kuryakyn.com/Products/382...der-for-Harley
i have one....works excellent....brake and running light and tailight all built in. i have the brake light on the top instead of the bottom
  #34
Old 07-29-2012, 07:57 PM
HarleyScuba's Avatar
HarleyScuba
HarleyScuba is offline
As mentioned above, Figure Machine has a really nice side mount. Here is their lit version. The mounting bracket is machined so that the wire for the LEDs is concealed. Outstanding! They have a unit without lights, too, as well as a slew of other cool parts.
  #35
Old 08-05-2012, 02:27 PM
Yo Nadz's Avatar
Yo Nadz
Yo Nadz is offline
How/where do you wire this?? Does it have the wiring with it?? Any additional pics?
  #36
Old 08-05-2012, 02:55 PM
Thorshammer's Avatar
Thorshammer
Thorshammer is offline
I used the stock location and did this>
Gonna pick up some black allen heads or black acorn nuts. Vertical plates are legal in Florida.
  #37
Old 08-06-2012, 01:37 PM
DallasSportster's Avatar
DallasSportster
DallasSportster is offline
It was not hard to wire. It comes with an LED light with attached wiring. I had to drill a small hole in the groove of the backplate for the wire to exit. It runs down a channel in the bracket. I then ran it along the back side of the swingarm and up into the battery box area. I used zip ties to secure the wiring and you can barely see it.
  #38
Old 08-06-2012, 01:56 PM
100yr_itch's Avatar
100yr_itch
100yr_itch is offline
Hey California riders...!!!...the law is 12" to the bottom of the plate from the ground or higher,no lower,and must be horizontal.and lighted.I want to do this also so I have a CHP friend and he checked it out for me...I had to edit a little.
  #39
Old 08-06-2012, 08:03 PM
blindrocket's Avatar
blindrocket
blindrocket is offline
I simply shortened the stock plate mount and turned the plate so that it would mount vertically.
It wasn't even a five minute mod.
rjacobs
11-01-2018 11:34 PM
Felix 808
2014-2023 Touring Models
14
03-17-2015 09:21 PM
Tinker55
02-27-2015 11:29 AM
Doughboy
05-19-2009 09:22 AM
DGFIRONWORKS
02-05-2006 12:08 PM
Quick Reply: Plate relocation - how?
