Oil Tank Fix or Replacement?
Old 07-15-2012 | 12:17 PM
Debonair's Avatar
Debonair
Default Oil Tank Fix or Replacement?
So whoever had it [2004 Sportster XL1200C] before me used a somewhat long self tapping screw for the oil tank cover on the left-side. Last night i must have gone over a bump or something and it punctured the very top of the tank. It would then leak when the bike is leaning/parked. To get it home we used a screw about the same size to plug it up which helped.
Where online would I be able to get an oil tank? I haven't had much luck.
Or perhaps is there some sort of fix i can do on it?
Old 07-15-2012 | 12:33 PM
Rog48's Avatar
Rog48
JB Weld?
Old 07-15-2012 | 12:35 PM
Mike07FLHTC's Avatar
Mike07FLHTC
you could have it welded.
Old 07-15-2012 | 12:39 PM
Rog48's Avatar
Rog48
I thought the tank was plastic...my bad
Old 07-15-2012 | 12:58 PM
cHarley's Avatar
cHarley
The tank is plastic, so I don't think welding is going to work too well.
Being it's in the top of the tank and the tank is not pressurized, a repair shouldn't be very hard. The trick is going to be getting the area clean of oil. I'd use a strong, slow curing epoxy for the patch, with a small piece of fiberglass mesh imbedded in the epoxy for strength.
Old 07-15-2012 | 03:50 PM
HarleyScuba's Avatar
HarleyScuba
Gas tank epoxy putty.
Put an o-ring under that screw you used.
Bubble gum and duct tape.
Old 07-15-2012 | 06:48 PM
Mike07FLHTC
http://www.eastwood.com/tpo-teo-and-...-80w-iron.html
Plastic welder $70 bucks
Old 07-15-2012 | 09:19 PM
xFreebirdx's Avatar
xFreebirdx
+1....
Yea that would last a lifetime. Some lacquer thinner should clean up the oil.
Old 07-15-2012 | 09:37 PM
Debonair's Avatar
Debonair
I think I'm going to go this route. Awesome, thanks a lot!
Old 07-15-2012 | 10:29 PM
mrmikey32's Avatar
mrmikey32
I have that plastic welder. lol
Use it more then i thought i would.
Quick Reply: Oil Tank Fix or Replacement?
