Urgent Help needed on Wiring system of Nightster.
hi guys,
i am trying to take out my rear fender so that i can chop it however i am stuck at some stupid wiring system.
I cant seems to unplug it!
There are 5 wires connected to a Connector.
2 of the wires are for the signal light
1 for the taillight
and 1 for the White Number plate light.
the other one i got no clue about it
but the point is that, i need to unplug all the wires before i can take out my Rear Fender.
i have attach some picture.
Can any kind soul pls help....
Thanks in Advance guys.
1 for the taillight
Gee do not cut it. There is a $30 tool for doing it but a cent small paper clip will do it. There is a little flexible barb stamped into the connections. It prevents the wire from coming out were the wire and connector goes in the plastic plug. GENTLY with the straightened clip push in on side opposite of wire and it will keep barb down and GENTLY pull on the wire. Its an acquired trick without with the paper clip. As difficult as breathing once you know it. Some of these plugs also have a small raised tab on one side that may be this one. It sort of hinges up and lets the wires come along with the pick. What ever you do MARK them because it does make a difference how they go back and I if you do not in 1 minute you will look and say to your self did the green go on the left or right.
