Quick Carb Adjustment Question
Over the weekend, I managed to switch out the slow jet on my carb with a .42 jet, after realizing that a .44 was too much. I did it to try to aleiviate the hesitation/carb 'pops' when I take off. (only mod related is a K&N air filter filter and kit; it was 'popping even before the mod).
I also put in the EZ Adjustment screw. That was a good move in hindsight!
Question, 'cause I just want to confirm it: When tuning the carb when warm, you turn it in until it stumbles, then 1/8 turn it out to start? I ask because I can't make it stumble, which is making me slightly nervous. I am getting some 'pops' in mid-range now, but nothing at the 'starting off' end.
Turn Out = richer?
Turn In = leaner?
Right?
Turn Out = richer?
Turn In = leaner?
Right?
Turn Out = richer?
Turn In = leaner?
Right?
Turn Out = richer?
Turn In = leaner?
Right?
Start with the bike at normal operating temperature and the mixture screw turned out 2.5 - 3 turns and the idle speed turned down as low as it will go without stalling, then turn the mixture screw in until the motor starts to stumble, then turn it back out 1/4 turn.
If the mixture screw has to be turned out more than 3.5 turns to get it to idle properly, you need to go up a size on the pilot jet. A 44 is a non standard aftermarket jet size. Standard CV jet sizes are 42 - 45 - 48.
