what bolts do i use???
ok i sold my hard bags,,with the mounting brackets ok
problem,,,i need to know where and what bolts i get to
run threw my factory,,,tail-lights and sissy bar???i want
chrome heads or something,,im lost..all help gratefull
not even sure what size to get,,or where to get them??
thanks
thanks
RE: what bolts do i use???
You can take an approximate measure by putting in a smaller diameter bolt. One that will slip in and out easily. Most marine stores have stainless steel bolts of various sizes that you can then purchase. You could also buy a longer bolt and cut it down to size if necessary. Use a C-clamp to hold the hardware in place if possible to get it all down right.
