View Poll Results: Brake line options
Bend stock line
![](https://www.hdforums.com/forum/images/kirsch/polls/bar2-l.gif)
![](https://www.hdforums.com/forum/images/kirsch/polls/bar2.gif)
![](https://www.hdforums.com/forum/images/kirsch/polls/bar2-r.gif)
![](https://www.hdforums.com/forum/clear.gif)
40.00%
Replace with braided line
![](https://www.hdforums.com/forum/images/kirsch/polls/bar3-l.gif)
![](https://www.hdforums.com/forum/images/kirsch/polls/bar3.gif)
![](https://www.hdforums.com/forum/images/kirsch/polls/bar3-r.gif)
60.00%
Voters: 5. You may not vote on this poll
10" Z bars install question
First and foremost, I have read countless threads on the topic.
So my question is since I am installing 10" bars I know the brake line is borderline on if it will reach. I have been seeing that some people advocate to simply bend the stock line to make it reach and others opt to replace the brake line. I don't mind replacing if its necessary, but if it isn't then I dont see the point.
To replace or bend? Any help or opinions would be appreciated.
Thanks
Here is a pick of my bike for good measure. Currently drag bars with all stock lines. 08 Nightster
Thanks
Also the stock cable is a rubber line. They expand when brake pressure goes through them wich equals less pressure going to the caliper. They rot from the inside out and you wont know its bad until it blows a hole when you really need your front brake. Steal braided line wont flex and will give better fluid flow to the caliper. Safety 1st!
