AUXILIARY BRAKE/ RUN/ TURN SIGNAL CONVERSION KITBulb Help!
I have the "AUXILIARY BRAKE/ RUN/ TURN SIGNAL CONVERSION KIT" installed on my 2005 XL1200R and a bulb burned out. Neither of the two bulbs has a readable number on it. Can someone tell me what bulb I need to get? Is it an 1157 dual filament, single filament, or some other bulb?
Thanks in advance!
Thanks in advance!
Photos?
You can pretty much look at the base and figure it out. I bought LEDs from SuperbrightLEDS to replace all my rear bulbs. On their site they have diagrams of the different bases with dimensions so you know what your ordering.
Is the conversion you speak of the one from JP cycle that goes under the seat?
Photos?
Motown_HOG
07-14-2008 01:47 PM
