cam and stage 1
You might wanna do an NRHS 1250 kit with that, the added displacement will help.
You could do the 1250, that'll give you a boost for now, and then later do the head work and cam. Some have said the .536 cam is a little better (and less noisy...) than the .551 cam. For now though you could just do the .497 cam or an Andrews N4 cam instead of the .551 - you'll still be well above where you are now.
do it all at once. pull your heads and ship them when you order your 1250 kit and cams. i think you might be happy with the se. 497 or n4 cams. that combo turns it into a bike that can be ridden causally all day and stretch your arms out if you want to wind it up.
