04 883 Help
04 883 Help
So I'm into chopping stuff off my bike and continuing with that thought I went and took my crankcase cover off. The problem I am having us that with the cover came a gear that was not supposed to come out, this gear us on a shaft with a knuckle behind it that pushes a plunger up. I'm assuming this assembly governs the timing, when it came out it lost its placement. So in trying to get this gear back into place but it is getting hung up on the before mentioned plunger that comes down from inside the motor. My question is how do I get thus back into place without moving the other gears? Can I just push it in? Will that plunger go up? Please help, I'm nowhere near being a motor guy and I feel that I made a grave mistake. Thanks Kyle
Do you have a friend or know someone that is a "motor guy"?
Do you have the Service Manual for your bike?
I do have a motor guy but he is hard to get a hold of. Thank you for the info on the tappet, I was afraid to mess with it or try to push it back up. I think with this info I should be good to go. I can like the cam up without too much hassle, I just couldn't get that 1 can back in because the tappet was in the way. I really appreciate the quick responses, this is my first Harley so I use stuff like this to learn. Thanks again and I'll let you know how it goes when I get it done.
Did you get it yet? If not, try rolling bike or tire to change position of motor. The push rod may be keeping you from pushing it up by hand, or the push rod is not going into tappet. The tappet should push up easily.
