2009 Nightster fuel light stuck on.
Hi, new to the forum. Just bought a 2009 Nightster. My wife was riding it the other day, stopped on a slanted road and proceeded to put her foot down on the downhill side (You can guess what happens next)
Anyways, now I have two problems. One, the fuel light will not shut off. Two, I am hearing a ticking sound (sounds like a valve). The bike runs fine, rides fine, seems fine other than those two things. She was at a complete stop when it happened.
Any ideas as to what could be wrong? Any help would be greatly appreciated.
![Icon Cry](https://www.hdforums.com/forum/images/smilies/icon_cry.gif)
How screwed up would screwed up have to be? I did check the pipes... no scratches, they were tight, everything seemed fine there. I took the rocker covers off and oil is getting to the top of the engine.
How loud is acceptable for the top end of the engine? I have loud pipes and I can still here that tick very clearly. It turns more into a hammer tapping sound if I really goose it. The tick also gets much louder if I use the engine to break. If I cruise in 5th gear at 60-65 it sounds like normal. It gets worse as the engine gets hotter.
I know people on the forum have complained about ticks/etc on the forum. And I know they say changing the oil helps. But this bike wasn't doing this 2 days ago.
RAL
So I took the pipes off. The front gasket was a little messed up.
In the process of taking the pipes off, I busted not one, but two exhaust studs! So, a quick and easy ~30 min job turned into a weekend long surgical extraction.![Icon Badrazz](https://www.hdforums.com/forum/images/smilies/icon_badrazz.gif)
When I finally got it all put back together, nothing had changed. What a nightmare
![Icon Bricks](https://www.hdforums.com/forum/images/smilies/icon_bricks.gif)
reeder22
07-06-2009 07:22 AM
