Now that I found out that the grey engine covers are a bitch to clean, I am looking for ways to avoid oil dripping all over the engine case when popping off the filter.
So, what do you use?
Cut milk jug?
Any other clever way?
I spray the area down with simple green full strength before starting, which keeps the oil from sticking.
I usually punch a hole in the filter with a phillips screwdriver and a hammer, drains most of the oil out, and makes the filter a lot easier to remove.
I use the H-D 3/8" drive filter "wrench" deal and don't worry about the oil at all as it really only gets on the small rounded section (lower motor mount?) directly underneath. After I get the new filter on I'll spray it all down with some electrical contact cleaner and it cleans right up like it never happened. Not sure why so many have "issues" with the grey cases staining.
