Found a work around for passenger pegs with solo bags..... you can use pegs and run bags if you swap the L & R pegs, put the left on the right and the right on the left, only thing is when folded up they lean forward instead of leaning back. I still need to space them out some but they work like they are now, and yes the left peg folded up clears the primary cover.
Thanks, it's not a cover , that is the air cleaner assy, picked it up on eBay. They use to call it a bug eye back in the older days.
Very cool, I like it a lot. Do you have to use breather bolts with it?
I noticed the same type of air cleaner on another Iron and lusted after it.
I'm trying to decide on what to use in the future. I've considered going to a Velocity Stack.
Don't have to use the bolts, I had the breather tube assy but did not like the looks.
