How long can your bike sit before battery dies?
I have a 76 Sportster with a new battery and let it sit in my bike over the winter. When I pulled it (the battery) out to check it the battery was greater than 80% charged. Sounds like a weak battery that is going bad. I'm sure if you ran the bike more it would stay charged longer in between rides. I would still take the battery in and have it checked. Keep the shinny side up!
Received 21,338 Likes
http://www.walmart.com/ip/Battery-Te...unior/15779492
or
http://www.walmart.com/ip/Schumacher...arger/13005742
No it's not normal! Admittedly I don't live in a hot climate, but I would expect that to make life easier for a battery than in colder climes. A tender will get around the problem you have, but it seems likely a new battery is in your stars! Once running, it is well worth checking the charging, to ensure everything is working properly.
