mirror adjustment- do you see behind you?
I have a very different perspective on mirrors than most of the responses here so far.
I adjust my mirrors as far to the sides as practical. It's easier to see someone beside you that way and if you ever need to take evasive action seeing what might be beside you is a lot more important than what's behind. I want to know who's beside me with a quick glance. And then just move your head a little to see behind you when necessary. If you are paying attention and check your mirrors regularly you should rarely ever be surprised by someone coming from behind.
And for those convex stick-on mirrors... those things are so distracting to me I would never in a million years install them. In fact, I just bought a truck that had those on it and I had them removed within the first 24 hours of owning the truck.
I adjust the mirrors in my car in a similar fashion. I'll pick an object out in the left and right side of the rear view mirror, then without moving my head, adjust the side view mirrors out as far as possible without losing the same object I see in the rearview mirror from the inside edge of the side view mirror.
I'll chime in.
When I had 12" mini apes the stock mirrors worked over or under.
When I had 14" Nash Grit Hangers I could NOT hang them under but could see perfectly with the mirrors on top, even with the small 3" ers.
Now I have low bars so under works fine (better). Stock would work better than 3".
+1 there's a reason they're called side view mirrors
When I'm driving a cager, I need to crank the mirrors out almost all the way, and then I end up with an uninterrupted panoramic view of everything behind, and beside me. By the time anybody is in front of my side view, they are already in my peripheral vision. My motorcycle mirrors are set almost the same way (minus the rear view, obviously) but I'm still more comfortable cranking my head around to see around me... something drilled into us by the safety instructors.
I'm considering bigger mirrors so I don't have to move my head all around to change the point of view to see everything behind me in the mirrors.
I use the the left mirror to see anyone directly behind me, which covers the left lane for lane changes too. It gives me a long view down the road behind me too.
It's the right one I've had to adjust to see the right lane better when on a 4 lane roadway or expressways. The right mirror covers the blind spot to the right that I'd have to really turn my head to see, and it gives me a long view behind me.
Mirrors are so important to keep track of what is going on around you, to stay out of trouble. Couldn't tell you how often I have watched the traffic coming up behind me causing me to maneuver out of their way.
