Jumping Sportster with Car Battery ? Yes or not?
Old 05-29-2012, 11:55 AM
commandozx's Avatar
commandozx
commandozx is offline
Default Jumping Sportster with Car Battery ? Yes or not?
hi guys....
some say its ok to jump start with the car battery.. .some say no....
pls help.. my nightster's battery is flat! ...
thanks in adv.
p/s: i mean jump start.. not a jumping sportster lol...
Old 05-29-2012, 11:56 AM
2011Deluxe's Avatar
2011Deluxe
2011Deluxe is offline
Not a problem, you probably dont even need the car to be running.
Old 05-29-2012, 11:58 AM
ElectraGlideSteve's Avatar
ElectraGlideSteve
ElectraGlideSteve is offline
Much safer to buy or borrow a battery charger.
Leave it hooked up and plugged in when cranking. There's even a start setting on the newer ones.
Old 05-29-2012, 12:00 PM
Scaredofrain's Avatar
Scaredofrain
Scaredofrain is offline
If you must. But I would run the car idling at most.
Old 05-29-2012, 12:05 PM
Shredding rubber's Avatar
Shredding rubber
Shredding rubber is offline
Sure you can. They both run of a 12 volt system it's just the car battery has more amps.
The car doesnt even need to be running.
I had to jump start my Honda a few times this spring and didn't have any issues at all.
Go for it. 12 volts is 12 volts
Pugslycat01 (10-01-2021)
Old 05-29-2012, 12:12 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,249 Likes on 1,640 Posts
If it was my only choice because I was in middle of nowhere - sure, but DO NOT START THE CAR'S MOTOR because the extra power from the charging system will possibly destroy the motorcycle's charging system and could cause a fire. The car battery should have enough power to start the motorcycle without the car's motor running.
Old 05-29-2012, 12:32 PM
cHarley's Avatar
cHarley
cHarley is offline
+1 - Unlike most modern vehicles, Harley uses a "shunt" type voltage regulator which dissipates excess current to ground. DO NOT jump the bike from a running vehicle.
No, it's not a case of 12 volts is 12 volts and this isn't a Honda, you can easily blow your 22 amp regulator by hitting it with 100+ amps from the cage.
Old 05-29-2012, 12:51 PM
Ironman 883's Avatar
Ironman 883
Ironman 883 is offline
Don't you know how to push start a bike?
Old 05-29-2012, 01:00 PM
osb's Avatar
osb
osb is offline
DO NOT START THE CARS ENGINE OR YOU WILL MAY POSSIBLY EXPLODE THE BIKES BATTERY! It is more likely you'll fry your electrical system or a fuse...it'll be bad!
Don't start the car!
Old 05-29-2012, 05:00 PM
IBGary's Avatar
IBGary
IBGary is offline
Get a charger, you'll need one sooner or later anyway.
Quick Reply: Jumping Sportster with Car Battery ? Yes or not?
