Damaged ECM connector, PLEASE HELP
Old 05-27-2012, 04:04 PM
chaddallas's Avatar
chaddallas
chaddallas is offline
Default Damaged ECM connector, PLEASE HELP
I have a 2007 Nightster and I relocated the ECM that was under the seat when I pulled the fender off. Well the rear tire rubbed through the gray connector that attaches to the ECM. Does anyone know where I can get this part??? Bike is out of commission till I get this part so please help so I can get back on the road!
Old 05-27-2012, 04:56 PM
Judge1989's Avatar
Judge1989
Judge1989 is offline
Can you post a picture of the damage? If its just the plastic you can reshape the connector with plastic weld. This does not mean weld it together. Or if the wires are damaged they shouldn't be difficult to fix. Picture of damage is needed tho.
Old 05-27-2012, 05:01 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Ragnar Danneskjöld is offline
I broke mine and just taped the damn thing back together.
Old 05-27-2012, 05:42 PM
chaddallas's Avatar
chaddallas
thank you for replying guys. ya its like the actual connectors and wiring that is jacked up. my rear tire got ahold of it and completely yanked it from the ECM. My ECM looks to be ok but this plug is done as far as I know.
Old 05-27-2012, 05:49 PM
chaddallas's Avatar
chaddallas
Old 05-27-2012, 05:51 PM
chaddallas's Avatar
chaddallas
this is the closest thing to it I have found online but I am not even sure this is the right part or how to tell. I dont even know what its called besides a connector
http://www.mouser.com/search/Product...EAqbMoaA%3D%3D
Old 05-27-2012, 05:53 PM
Ragnar Danneskjöld
https://www.hdforums.com/forum/elect...r-problem.html
Old 05-27-2012, 05:57 PM
Judge1989's Avatar
Judge1989
Looks like the connector comes apart. See if you can open it up. Should be able to find round pin connectors at local parts house. Crimp them on and give it a touch of solder. Place pins with a dab of superglue back into connector. Zip ties and black electrical tape should hold it together. Find a wiring diagram to make sure you get them in the right place. When soldering don't put to much on. Solder creates resistance and may give the ecm false readings. Good luck!
Old 05-27-2012, 06:00 PM
chaddallas's Avatar
chaddallas
no way of just replacing the whole thing I guess?? If it comes to this I am taking it in cause that is more than I want to do on my own. Not a fan of electrical.
Old 05-27-2012, 06:01 PM
chaddallas's Avatar
chaddallas
ya this is where I found the link to the one for sale. his bike is a FXDLI. do they use the same connector?
Quick Reply: Damaged ECM connector, PLEASE HELP
