No electric PLEASE HELP!!
#31
#32
#33
#34
ignition wires
Well, your test results indicate that the wiring doesn't follow standard electrical conventions and that's likely the result of the bob tank install.
See if you can follow and figure out where the red and white wires go to.
Did you try touching the green and red wires together?
yes tired them all nothing,the bottom of the ignition plate which is plastic is cracked may be my issue but still dont understand why now I have no power?? green one has juice but other 2 dont RED and WHITE hooked to dash post with nut along with black wires GREEN to post on dash along with with a RED wire coming in from harness
#35
"RED and WHITE hooked to dash post with nut" - They're hooked to the same post?
"along with black wires" - Where did the black wires come from? You only had green, red & white before.
#36
Sorry, it's hard enough trying to diagnose this without seeing the bike and already knowing that the wiring was kludged by someone else, but without better detail and sentence punctuation I'm lost.
Im sorry not the best typist. yes there about 4 post with wires on them nutted on.
I come to these forums for some input but as always Im smart enough to figure things out
Hope you work through that punctuation thing.
#37
Same mysterious issues, electricals going dead.
I'm experiencing the same issue on my 98 Ultra. Sitting at a light last night with the bike idling, the engine started faltering and all lights started flickering, and then........silence. The engine quit and bike was completely dead. I flipped the ignition on and off a couple of times. The lights came back on, I hit the starter. "Karooom!..Vroom!...putt-putt-putt-putt. Silence". Gone again. This repeated a couple of times until I just left it off until I got the green traffic signal. Quick then I hit the starter, dropped into gear, and got it moving fast............and the problem was gone. Hasn't come back yet, but I am thinking I will be checking the battery connections first. They had the seat off yesterday just prior to all this for an upholstery repair.
