Peanut Tank miles???
so i just bought a 96 sportster 883 with a peanut tank and i was wondering how many miles you guys get out of the tank? right now before i switch to reserve it does 55 miles then i have to put it down to reserve.....also i have read that theres a break in period. my 96 was just sitting around not ridden so it only had 990miles when i got it, now it has about 1170 miles. will i get better mpg after i log miles on it, is somthing wrong with my bike? or is this the risk im have when having a cool looking peanut tank. thanks guys
BarnabyBey883 (07-24-2021)
I have a 01, with the nut tank. I look for a gas station about once every 100mi. Took it up to 120ish without hitting reserve. I weigh about 135 and keep my RPM around 2.5-3k sometimes ******* it. You mileage will improve after your 3k and 5k marks but I'd say your still looking low.
sorry im sure i could look this up but is ur 01 FI or carb??? i saw others say about 60-70 tops on carb sportsters but with the bigger tank getting upwards to 100 mileper tank
Originally Posted by intense883;[URL="tel:9852639"
9852639[/URL]]sorry im sure i could look this up but is ur 01 FI or carb??? i saw others say about 60-70 tops on carb sportsters but with the bigger tank getting upwards to 100 mileper tank
I just filled mine up, 61 miles in 1.3 gallons, works out to 47 mpg.
Just put some Seafoam in for the very first time (13K on her), and she seems to run way smoother. I'd buy a can ($9.00 at Walmart), put in a couple ounces and see if that helps.
I think I've gotten close to 50 mpg, but I've been fiddling with my carb mix lately, so I've been on and off the throttle when I've been out.
John
John
John
John
so you have the 2.2 tank? thats about what im getting and i rebulit my carb becuz it was sitting for so long it kept clogging the jets now its all good i think just was ify on the MPG im getting
so are you getting 60 before or after u switch to reserve im guess before since u said 1.3 gallons to fill up. thanks for all input more peanut replies are welcomed lol
