cant take the front brake mounting bolts off
05-24-2012, 10:53 PM
I cant seem to take the front brake mounting bolt off my 2007 Sportster. I have a whole socket wrench set and I used the one that fit the tightest and it would still slip. Any advice? Thanks
05-24-2012, 10:55 PM
are they allen bolts, if not are you using a 12 pt. socket?
05-24-2012, 10:59 PM
no i was using 11pt socket, 12 was too big. The bolt is not a Hex bolt either. Its got like 15 tiny pts.
05-25-2012, 04:46 AM
on my 2004 I use a 10mm 12pt .
05-25-2012, 06:22 AM
10mm 12 point socket...PB blaster...them give it a good tapwith a hammer to shock it ... then try it again...also could try heat...some like to use heavy duty loctite....
05-25-2012, 07:51 AM
10mm 12-point box end wrench tapped with the above mentioned hammer...it will not slip. Please don't hammer your ratchets.
05-25-2012, 10:17 AM
10 mm 12 point socket, or closed wrench.
05-25-2012, 10:23 AM
let the PB blaster marinate for a day or so
05-25-2012, 12:14 PM
Thanks Everyone! I was using a normal socket wrench on it, guess I have to go pick up a set of 12 pt wrenches!
DOMAPOI
09-18-2020 03:09 AM
Jpatterson317
02-27-2017 08:31 AM
Falcon195
10-15-2014 01:14 PM
jed1069
08-11-2009 02:00 PM
pip369
Wheels/Tires
11
03-16-2009 06:52 AM
