Oil change
I believe the .8 qt goes into the oil the filter before you install it.
I did my 1,000 oil change on Saturday and did 2.0 quarts, per the manual. I then ran an errand to see where it was on the stick and added a bit more.
Speaking of which, I am so glad I did my first fluid changes myself. I'm not at all mechanically inclined and it could not have been easier. That little worm clamp was simple to drain the oil and the filter came right off with the HD filter cap wrench that goes on a socket wrench. Put the plug back in, tightened the worm clamp, put a little oil in the filter and a little on the gasket, hand tightened, then added the two quarts. Done. If I can do it, anyone can!
Here's a link to a YouTube video some cat did on his 07 nightster. Pretty good tutorial if you learn better with visuals. Helped me out a lot the 1st time I changed my oil.
http://www.youtube.com/watch?v=eMfRg...e_gdata_player
Yours and many other manuals are wrong.
HD manuals listed 3.6 quarts up until around 08. This quantity applies only to factory new, DRY motors, it is NOT an oil change quantity.
For an oil change, 3 quarts is max, and 2.75 quarts is recommended to reduce oil puke out the breathers.
This amount includes the 4-5 oz's that get poured into the filter before it's installed.
This has been posted here many times before.
