Clip ons
05-21-2012, 08:31 PM
Clip ons
I'm contemplating clip on's for my bike. What does this entail as far as brake lines, throttle cables, ect? All insight appreciated!
05-21-2012, 08:32 PM
You can get away with using the stock cables, but you'd definitely want to get shorter wires to clean it up.
05-21-2012, 09:20 PM
I inquired about this recently. Couple people said everything stock worked fine. Haven't done it myself yet.
05-22-2012, 01:07 AM
Quote:
Originally Posted by
theterribleone_vdc
clutch cable about 4" shorter
throttles about 3" shorter
brake line (you will need a new one made up
thats if you want it to look tidy that is
05-22-2012, 04:33 AM
I made some for a Nightster but they mount the same as any other clip-on
I just ordered a 12" shorter clutch cable & throttle cable (running single throttle cable) and I shortened the hard line in the brake line myself.
You can see how long the stock throttle cable is here
05-22-2012, 07:17 AM
Thanks for the help, guys.
Mreed, you do some cool stuff. How does one go about shortening the hard line himself?
05-22-2012, 08:43 AM
mreed
Mike, i really love the look of the single bar clip on's you made. Killer work as always.
05-22-2012, 10:18 AM
Youll definately want a new brake line, but you can make the factory one work it just sucks with the steel section between the rubber sections
05-22-2012, 11:57 AM
theterribleone_vdc
Check out the Alloy Art Speed Down Bars. They are a happy medium and they'll work with no mods.
05-22-2012, 04:27 PM
Thanks
I removed unnecessary length from the hardline and used a compression fitting to plumb it back together. It's a regular old brake line...just like a car.
cripple
12-11-2012 12:19 PM
jordanball33
08-28-2010 02:21 AM
twitchy
04-30-2010 10:10 PM
Rev00
01-09-2008 06:22 AM
Puttnutt24
02-20-2007 10:37 PM
883 ,
brake ,
cable ,
clipons ,
clutch ,
ends ,
iron ,
licks ,
line ,
lines ,
shortened
