Sportster rear brakes
My wife has an 06 custom 1200. My son was attempting to pull her back tire off so that he could have it replaced. In doing so, he removed the rear caliper. He was not able to finish the project, and so, I replaced the rear tire, but, for the life of me, I can't figure out how the caliper goes back on. I have it in place, but, the one bolt that holds the caliper in place has a short thread with the rest of the length being a sort of pin. The bolt, because of the thread length, only screws into the caliper, and not the frame. So, it does not stay in place. When I extend the piston, it just pushs the caliper out from where the pin portion sits (in the frame). Anyone able to shed some light on this for me?
This is a floating caliper. The large pin in the front threads into the caliper itself...the smaller pin aft threads into the caliper bracket that slides on the swingarm.
Roll your tire's sidewall just past the caliper then position the axel spacers either side while wiggling the wheel into position for axel insertion.
Maybe I'm misunderstanding you, but, the tire is on the bike, and the caliper is in place on the rotor. There is one larger bolt on the caliper toward the front of the bike. That appears to be the only one that holds the caliper in place. The problem that I am having is that the bolt only has enough thread to go through the caliper. The rest of the bolt is a pin sitting in the bracket assembly. The back end of the caliper sits on a pit coming out from the assembly. Thus, it appears that I have to pins floating, and nothing holding the caliper to the assembly. I don't know if I am missing parts? Does anyone know where I can find an exploded view so that I can see what is supposed to be there?
Do you skype? I just worked on my back calipers this weekend and took pictures of each detailed step. Not sure if yours is exactly the same. Mine is an 1980 but same concept. I pulled the caliper apart to change the torn gasket, replaced the bolts.
There are a lot more experienced Harley owners on this website but if you still need help holler!!
I looked at the parts diagram Charley posted, not even close to mine, but still same concept.
Last edited by marine_hm@hotmail.com; 05-21-2012 at 11:33 AM. Reason: Not even close to being the same.
Thanks for the exploded and view and the advise guys. I see that my son tore off the rubber bushing on the back pin. That may have something to do with why the caliper keeps pushing away from the rotor. I also found the spring that was pulled out. Should be able to fix it from here. I'll try to fix it again on Friday.
