Brand new 2003 883 sportster
I recently got a 2003 883 sportster with extremely low mileage on it. Under 50 miles. It hasn't been started in about 4 years. It still has the original break-in oil in it. Do you think it willl be ok to use this oil still or should I have new break-in oil put in it?
Thanks
Thanks
I would change the oil and the filter! Drain the gas. Change the transmission fluid. If it were mine, I would probably change out several more things also. I would spend what ever it took to make sure I wouldn't have problems. I think you are supposed to change the oil, even if you don't ride much at least once per year, or maybe sooner. That makes me think other stuff probably needs to be changed out also. This is just my opinion.
Wow what a steal! Hard to believe someone would buy a bike and only put 50 miles on in 10 + years.
I would definitely change out the oil and gas in it. I might even have a mechanic check it out to ensure nothing else has corroded or broken down over that time.
How are the tires would be my next question.
Thanks
Thanks
