Derby Cover Swap
Derby Cover Swap
With my dealership credit, I'm going with the Roland Sands Clarity Line Derby Cover. (i know way over priced, but basically goinh to be free) Anyone out there have one? Would you get it again? How much stuff is going to come pouring out and what do I replace it with on 2011 1200 evolution motor? And, is there a gasket that comes with, or, do I have to get a new one separately. Thanks all....
I use the HD Formula+ transmission fluid, $8 at the dealership. If your bike is on the side stand when you take the cover off, fluid will come out. If you have a lift (or even a scrap 2x4 under the jiffy stand) to get it upright, you won't lose much, if any. It would be a good time to change the fluid if it's due, it takes exactly one bottle to change it.
Not sure on the gasket, they should include a new one, but you could probably reuse your old one if you needed to. I've never seen a clear derby cover on a Sportster, might look cool with the fluid splashing around.
Why would they do the timing cover, air cleaner, and no derby cover. D&$kheads...
They had some lame azz excuse that there isn't too much to see with a clarity derby cover for a sportster. Whatever....
