Probably screwed up.
So I got a relocation kit for my front turn signals and I've been havin a hell of a time getting the bolts on the forks to break loose. And I had to replace my mirrors because one of them snapped in half and the threads don't match up. So instead of letting the turn signals dangle down I went ahead and cut them off and tucked the wires into the top of the forks. Well I went out to start the bike for work and it had a hard time starting for some reason. Possibly low on gas. But it started then my headlight went out. I have no idea why but I think I may have fried the wires or something. Do any of you have any suggestions on what to do. FYI I have an 02 1200.
Ok I've gone back and checked my fuses. Didn't see anything abnormal. As far as I could tell. <--- amature. Double checked headlight bulb. It looked good. Turned key on with wired pulled out. Still had a hard time starting. Tested turn signals. Left one works properly. Right one stays solid. Both without the front turn signals hooked up. But still no headlight.
kmseitz
05-08-2013 10:07 AM
