Installed tank lift/reloc and bike wont start..... Advice is appreciated
Old 05-15-2012 | 06:15 PM
sickboy949's Avatar
sickboy949
Did you remove main fuse before u did wiring????
Old 05-15-2012 | 06:17 PM
sickboy949's Avatar
sickboy949
If not check fuses first before u take everything apart
Old 05-15-2012 | 06:18 PM
ArleeD's Avatar
ArleeD
Yes, and also unhooked the pos battery connection..... I checked the accessory fuse, but, it looked fine.... and as mentioned, the lights on the speedo and license plate work, but, nothing else....
Old 05-15-2012 | 06:19 PM
ArleeD's Avatar
ArleeD
I'm not the most experienced, but, I guess a blown fuse would be a "broken" filament in the middle, correct??
Old 05-15-2012 | 09:33 PM
sickboy949's Avatar
sickboy949
Yes . I had similar prob after washing my bike first time blew two fuses plate light came on and headlight but wouldn't start and no tail lights
Old 05-16-2012 | 09:25 AM
ceekay's Avatar
ceekay
A broken filament will cause your light to not work... However, the circuit should be wired in parallel so that if the headlight blows the other lights in the circuit (i.e. speedo light, turn signals and markers) would still come on...
I could be wrong, though.
- CK
marine_hm@hotmail.com
06-21-2012 08:43 AM
junior07
08-02-2011 05:53 AM
jmorris42
03-10-2011 12:28 PM
Beerninja
03-26-2009 09:35 PM
dynamac
12-10-2007 11:02 PM
Quick Reply: Installed tank lift/reloc and bike wont start..... Advice is appreciated
