Widest rear Tire - Stock Wheel
Thanks for the info Ergo! I'm surprised the belt is first to contact in your case, but I haven't checked mine specifically for this issue. I THINK my rear wheel sits closer to the right side by quite a bit so my guess was that the spliced wiring I did on that side or the strut hardware would contact first. I'll look it over good tonight.
btw, in my search for the widest 150/80-16 inch rear tire I could find I found the Continental Conti Tour was widest, at least in the online stats department. J&P Cycles website lists it at 164mm/6.46 inches wide. I thought about running them both front and rear on mine but decided on the Venom's due to the availability of the 150 designed specifically for the front and the Continental may require a 3.5" rim instead of the 3" rims I have. Opinions vary on that as well, so who knows?
Thanks man, very handy. Darn...not seeing any 160/70-16 tires...yet.
ETA: Thanks for that info Ergo. I'm NOT a fan of Conti's at all after having a set of 31x10.50's on a Ranger, that were absolute $#!T, but I suppose motorcycle tires may not be created equal. Think I'll steer clear none the less. I wonder if those K591's are any better than the stockers...that's what I am looking at now. Maybe I should focus on what do to with the front as I have more options there.
Might be worth a look.
The V-rated tyre has less tread depth than the H-rated. Also, of course, when riding on one we have to go over 130mph.....
The info isn't all that hard to find.....
ie. Google "metzeler ME880 technical" an look for the hits that link directly to the manufacturers website.
Metzler
Avon Venom
Dunlop E3
Metzler
Avon Venom
Dunlop E3
Anyone have any experience with the Dunlop Screaming Eagle gt502 ? .. if you look in this video it looks pretty fat on that iron:
http://www.youtube.com/watch?v=CSyNKe_hNLc&feature=plcp
All the info from the HD site is "16'' Rear - GT502 150/80B16 Blackwall":
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Note the custom (wider) wheel and the belt and sprockets look to have been moved outward to accommodate the wider wheel and tire. That's why there's no cover on the front sprocket.
I can't get to that site at work for whatever reason, but I did find some K591 info on another site. Supposedly Dunlop "discontinued" the K591 in favor of a K501, but "sold" the K591 to H-D to use as their "SE" performance tire. Only thing is they are softer for added grip, but mileage greatly suffers. Supposedly one guy got 16k on the D401, but only 5-6k on the K591.
