Mini Apes- Dealer quotes $788
I really don't feel comfortable with all that's involved with changing out bars, extending cables, etc., but this price seems absurd to me.
Are there any online resources that could help me through tools, parts, and a step-by-step how to so that I can do this myself?
That is, if $788 actually is absurd. I don't know, maybe it's reasonable? But the bars are only $70 apparently, and I can't fathom how the rest escalates the cost over 10x.
Any help would be appreciated
Just go step by step stripping things off and take lots of pictures... Dig around here - its been done before- and you'll find out what you need to buy. This is only a few notches above changing your own light bulbs.
Toughest part will be bleeding the brakes if you have to change brake cables... Prolly a good thing to know anyway.
As for tools- pretty basic- allen wrenches, screwdrivers...
Received 4,224 Likes
The Sportster manual will give you the step by step on replacing the bars & the brakeline.
You will also need a longer brakeline and I think longer electrical wires. The wire kit can be had from NAMZ, the brakeline from J&P.
The throttle cables are long enough, and if you need to, you can route the clutch cable over your forward controls instead of below them.
It is pretty straightforward if you follow the steps in the manual and that come with the NAMZ wire extension kit.
Parts, including the mini apes should come in below $300 and then you save the other $400+ by doing it yourself.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
It is a tedious job, but not complex. It took me a very long time and was frustrating, but it's doable. At 10", I'm confident that you will need clutch, brake and wiring extensions.
For the most part it's really straight forward. Some tips.
-Protect the front fender from brake fluid with a towel
-Pull the tank, don't prop it.
-Run the wiring inside the bars BEFORE extending it. With 10" bars, this shouldn't be a problem.
-Take good notes about the wiring and where it belongs in the connectors!
-You're going to need a lift for the clutch cable.. Find a friend with one.
Oh, and $788 is about average. This should take you the better part of a weekend if you've never done it before.
