plug wires
Old 05-01-2012 | 10:47 AM
falsealarm's Avatar
falsealarm
Default plug wires
I have a 2010 48
I want to replace the plug wires with orange ones
Any advantage to going with larger mm than stock
Any wire suggestions?
thanks
Old 05-01-2012 | 11:30 AM
WVHogRider's Avatar
WVHogRider
The only advantage is thicker insulating rubber & the color you want......Seeing as your plug wires are only two years old, there's no real reason to change them other than so you can have the color change. Just go with the Screamin Eagle wires. That's what I grabbed last year since I was replacing the original plug wires, 12 years old. Plus I wanted the orange.
Old 05-01-2012 | 12:09 PM
tandt's Avatar
tandt
What he said ..... the SE ones are the HD orange and you don't need to worry about how many mm the wire is, etc.
I laughed out loud when I got my SE wires. There was a big warning on the box about SE products being for off-road competition use only, like a set of wires was going to completely turn my 1200 into a hellfire breathing beast.
Old 05-01-2012 | 07:56 PM
Martads Bobber's Avatar
Martads Bobber
Haha I did the same thing. I did a DK coil relocation that came with the SE plug wires and had the same warning.
Old 05-01-2012 | 08:12 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
I have the SE wires. The type doesn't make a difference.
Old 05-01-2012 | 10:15 PM
Johny2x4's Avatar
Johny2x4
6th Gear
I don't want to derail your thread, but I'm looking to find some green plug wires. I have no idea where to begin looking. I've searched parts stores, online(google and the likes) and I have no idea how I would find the right ones for my bike. Does anyone know if it's even possible to find green plug wires? The scheme on my bike is black and green so I'd like to try to match them. JP has these: http://www.jpcycles.com/product/360-704 but 2011 48 doesnt show in the supported models area, and I have the DK Customs coil relocation kit so I also don't want one of the wires to be a mile long. Anyone got any ideas?
Old 05-01-2012 | 11:50 PM
tandt's Avatar
tandt
Plug wires aren't hard to fabricate. Check with a local shop - I've seen a skilled wrench fab a set in 5 minutes. The plug ends are generic, the wire stock can probably be had in any color.....even if you got a set the wrong lengths, simple to pop the plug off, trim to your length, and go from there.
Old 05-03-2012 | 05:57 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
The PRO RACE Wires consistently show 2% better on a Dyno than the Screamin' Eagle wires. Probably not enough to tell a difference in riding.
We have never done a comparison between the stock wires and the Screamin' Eagle.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
Call/Text: 662-252-8828
Old 05-15-2012 | 02:38 PM
barry cummings's Avatar
barry cummings
Stage I
Default change puge wires requires tank removal?
I got a "01 Road King Cop Bike. My stock wires (45k on them) are tucked under my tank and look clipped intp the bottom of the tank. Is there a easier way to change them than removing the tank???
Old 05-16-2012 | 04:17 PM
WVHogRider's Avatar
WVHogRider
You might want to ask this in the "touring section" instead of the sportster section........But, you should be able to disconnect/open the clips with a screw driver/finger fidgetting the wires.
Quick Reply: plug wires
