Best Tuner options?
Old 04-28-2012, 11:41 AM
Rich00748's Avatar
Rich00748
Rich00748 is offline
Default Best Tuner options?
My dealer was $700 to install an HD Tuner, and dyno tune my bike. That just sounds crazy to me. Only changes are SE intake and putting a set of V&H pipes on it nothing more.
Anyone have a good opinion on the V&H tuner? Cobra? Or is the HD Tuner the way to go?
Also, any recommendations on a great service shop in the Houston area? I like my dealers sales guys, but I have never thought too highly of their service dept.
EDIT: This is a 2011 Forty-Eight
Old 04-28-2012, 12:55 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
Have You looked at a thundermax? It will cost you $850, but you will never need another dyno.
Old 04-28-2012, 01:03 PM
siryan's Avatar
siryan
siryan is offline
how about the xieds?
Old 04-28-2012, 03:48 PM
MikeZ's Avatar
MikeZ
MikeZ is offline
That price sounds about right. I went that route on my Heritage and I am VERY pleased with the results, and especially the torque gains. The one issue with the SE Pro is that it's married to your bike, unlike the aftermarket choices. Do you plan on keeping the 48? Are you considering possible cam work in the future? If so, the HD tuner would be a good choice.
Old 04-28-2012, 06:54 PM
wanabe's Avatar
wanabe
wanabe is offline
i like the techlusion fuel management... you can adjust it like a carb- and it is only about $250 or so. very easy to use- combine this with a new air sucker and pipes and you will not recognize the performance that your bike will give you!
http://www.dobeckperformance.com/TFI/TFItechnology.asp
Old 04-28-2012, 07:03 PM
smitty901's Avatar
smitty901
smitty901 is offline
Received 10,349 Likes on 5,493 Posts
Best tune you can get SERT on the DYNO by a pro.
Wow it is going to cost you but the best is the best.
Few if any need it.
Next is the PCV type systems TFI Gen4 high end very good costly and over kill for most
real world for most street riders TFI gen 3, or one of the cheap simple piggy backs with simple pot setting.
Old 04-28-2012, 09:39 PM
aklim156581's Avatar
aklim156581
aklim156581 is offline
Few if any need it.
I'll bite. Why is SERT better than SEPST PowerVision? They seem about the same except the data-logging, as I am understanding it, is better on PowerVision. PowerVision might not be popular with the HD dealerships but others own a dyno that can tune it too. My SEPST was professionally tuned but I can't see how it is different than SERT or PV that is professionally tuned.
Old 04-28-2012, 10:53 PM
Rich00748's Avatar
Rich00748
I do plan on keeping the bike. I just don't want to drop cash on something that is a complete waste. I will probably have the dealer install the tuner and do the dyno after I install the pipes. Time to cash in some vacation $$!
Old 04-28-2012, 11:13 PM
aklim156581
I honestly don't think what they are asking for is ridiculous. Look at the HD catalog. SEPST costs $460 so make sure they are giving you the Screaming Eagle Pro Super Tuner and not the Street Tuner. I got about 20% of sometimes so it makes it $370. Dyno tuning around this area is $300, give or take. So you see $700 isn't outlandish. My under, which is standing, is that the engine runs lean from the factory. EFI can compensate TO A POINT. By adding an AC and pipes, you are taking restriction out. More air and same fuel means a leaner than stock condition. Could it push the thing out of the compensation window? It could. You can see my graph HERE and see that the AFR was a little higher than it should be with AC and pipes. I planned for a dyno tune when I did pipes and AC.
What is this "vacation" and "$$" you speak of? Is it something you get easily? I heard some mention of them but haven't seen enough of either to recognize them.
Old 04-28-2012, 11:47 PM
countryroads's Avatar
countryroads
countryroads is offline
I'm happy with my V&H Fuelpak. I bought a 2011 Heritage, and it pinged under load. I put a Stage 1 air cleaner (Harley part 29773-02C) and a set of Rush slip-ons on it. Pinged even worse. So I put the Fuelpak on and the bike had noticably more power, and the ping was history.
Quick Reply: Best Tuner options?
