48 cam? suggestions?
Well since you have the heads already done on it, that gives you a lot more choices for cam lift. Have you checked out the Andrews cams website? They give a good description of what you can expect from each type of cam setup.
Did the heads make a real noticeable difference on there own? What else are you running on your bike? Got pics?
For the price, there a rip-off IMO.
So basically they just give a bump in compression but don't really offer any flow benefits? That sucks. I haven't looked into them but I'd imagine for what they cost you probably couldn't pulled the stock heads the proper head/valvetrian work and cams.
The SE bolt ins or the Andrews N4 (both are the same grind) can add anywhere from 5-10HP on the top end of a bike with pipes, a/c and tuner with no head work. They really only extend the torque curve into the higher rev range and add that 5-10 HP between 5500 and 7000 rpm. I've seen around 5 dynos with just these mods on another Sportster forum.
