Oil check
Oil check
Boys....so i'm still getting a lot of oil blow by on my bike. i'm running the diy a/c from mreed and was also running the breather hose/small filter setup and wanted to go with some breather bolts to clean it up. first long ride to work, oil everywhere and wasn't even revving the thing overly excessive. i'm pissed to say the least. here's my question, the manual says check the oil on the stand (not sure why but ok) so that's where i always checked it (hot obviously). i was told by more than one person to run the oil level as low as possible to combat the blow by which i thought i was doing. if you can see it on the stick it has enough oil. ok. on the stand i'm just barely showing up on the stick, bike straight up and down i'm half way between fill and full. perfect right?
well i'm still getting blow by with this diy setup. i bit the f-ing bullet and bought a new xflow a/c that is made for efi's with the breather function built into the back plate. nice product! i ran a ness BS before that's also for efi's and that thing spewed oil like crazy so i got rid of it and went with the diy a/c which was ok with the breather tube setup as long as i wasn't hammering it for hours on end when it would start to mist or drip. as soon as i installed the breather bolts from DK, oil everywhere. so, i must be still running a little too much oil correct? if this new a/c does the same thing, that has to be it. i've heard of umbrella valves etc. sticking open that could cause this (hope that's not the case for me) but how are you guys checking your oil and is anyone else dealing with this? side stand or straight up? i get mixed feedback all the time so thought i'd ask. thanks guys! domo arigato....
On kickstand, hot, to full mark. No blowby, or very little anyway.
But as mentioned in another thread with a dry sump system there is always the same amount of oil in the engine regardless of how much oil is in your tank. Knowing that I dont understand the correlation between oil level and amont of blowby.
I just installed the same one a few weeks ago and I pretty much rev the **** out of my bike on every ride and no issues so far. As I stated in a previous post, I'm filling the oil level the same as you are bmx.
well i guess after i get this new breather on and test ride it i'll know. if it's still spewing, bike is going to the shop to have the valves looked at. i just don't have the time to rip into the motor. thx cHarley!
Received 4,193 Likes
I am checking mine on the side stand cold or hot...either way I want to see the oil level right around or a tad below Halfway between the two hash marks.
It could be the umbrella valves...and I hate to mention it, but one of the symptoms of a crank being out of true is puking oil out the breather bolts.
