While drunk last night I had what I thought was a great idea
Old 04-22-2012, 07:03 AM
Taddeoeg's Avatar
Taddeoeg
Taddeoeg is offline
If you're only going to run a rear brake (that's the part I'd call not the best idea) I can't see any reason not to control it with the lever. The challenge will be figuring out how to make that work. The lever/cable works on the pull while the linkage for the rear brake works on the push.
If you work it out it will fit really well with your forum name - - you're bike will be a motorized Schwinn.
Old 04-22-2012, 07:21 AM
Scratt's Avatar
Scratt
Scratt is offline
If it's a hydraulic brake he should be able to run a longer hose off the "front brake" master cylinder. Not sure if he wants to lose the foot pedal though.
edit
ok just re-read the post
not sure if you want to spend the bucks you could put a rotor/ pulley on and work that with the hand brake.
Old 04-22-2012, 07:29 AM
simmy711's Avatar
simmy711
simmy711 is offline
Ohhh I've thought all about this and many other options. Rollin on this bobber is a lot of fun on steep incline/declines and coming to a stop while still in gear and timing the braking and throwing down your right foot is buckets o fun. I got used to it, but it took a few months to build confidence.
Notice all my hand controls!!! LOL!
Old 04-22-2012, 07:30 AM
schwingding's Avatar
schwingding
schwingding is offline
Thanks for the reply, but I want to point out that your comment is not completely accurate. The linkage is different, but the brake works the same. The rear brake is activated with the same hydraulic action as is the front. The brake pedal pushes a rod that connects to the master cylinder - same setup as the front, different linkage is all.
I would simply remove the brake pedal, linkage, and master cylinder and use the hand control and its master cylinder to do the same.
Not trying to be a dick here! (just comes naturally)
Old 04-22-2012, 07:58 AM
Taddeoeg's Avatar
Taddeoeg
Taddeoeg is offline
No offense taken - you must be an amateur dick.
Naturally both m/cs work on the same hydraulic action - my point was about activating the m/c. And yes, technically even that is the same in that "pulling" the lever "pushes" a rod into the front m/c. Still, you need to get a connection of some sort from the lever to the rear m/c. I was thinking cable (not hyd line) from the leave (think clutch) back to some way to activate the rear m/c - hence the "push vs pull" issue.
Seems your idea is to scrap the rear m/c and run a long line from the bar-mounted m/c back to the brake and that would certainly work. Guess in my mind, from looking at your bike, I assumed you wouldn't want to clutter up the bars with a m/c. If that doesn't bother you, this will work.
Old 04-22-2012, 08:04 AM
smitty901's Avatar
smitty901
smitty901 is offline
Received 10,359 Likes on 5,499 Posts
Why not put the front brake back on? That would be a moment of genius . They make some good looking small add ons that work.
Old 04-22-2012, 08:11 AM
schwingding
Not so easy, and not completely necessary. The front fork legs have been turned down on a lathe, the brake mounts are gone.
Old 04-22-2012, 08:16 AM
got2bjennyg's Avatar
got2bjennyg
got2bjennyg is offline
While drunk last night I had what I thought was a great idea And now sober I still do, so help me pick it apart before I do it....
Drinking Alcohol May Significantly Enhance Problem Solving Skills
Scientists found that men who drank two pints of beer or two glasses of wine before solving brain teasers were quicker in delivering correct answers....
No input on your rear brake activation with the hand control specifically, but thought you might get a kick out of the article.
Old 04-22-2012, 08:24 AM
SamStone's Avatar
SamStone
SamStone is offline
How drunk were you when you decided to take off the front brake?
Old 04-22-2012, 08:54 AM
Mullenmc's Avatar
Mullenmc
Mullenmc is offline
Please forgive my ignorance if this question sounds stupid, as I am a novice (motorcycle) wrench turner, but would the front m/c hold enough volume of fluid to travel all that way and supply the needed pressure to drive the calipers? Seems you would have to use a smaller diameter brake line. Just a thought........a sober one.
Quick Reply: While drunk last night I had what I thought was a great idea
