Installed Flush Fender Light (Pics)
Old 04-21-2012, 09:25 AM
Martads Bobber's Avatar
Martads Bobber
Martads Bobber is offline
The forum strikes again. Something else I now have to save some money for! Looks nice.
Old 04-23-2012, 11:47 AM
GodIsStevePerry's Avatar
GodIsStevePerry
GodIsStevePerry is offline
Very nice looking!
Is it easy to access everywhere the light needs to be wired in/connected to when installing?
Old 04-23-2012, 07:37 PM
Mullenmc's Avatar
Mullenmc
Mullenmc is offline
Originally Posted by GodIsStevePerry
Very nice looking!
Its really easy. 20 minutes and I was done. The hardest part was removing the bottom shock bolts and lifting the *** end to get enough room, but other than that the wiring snapped right in to the existing harness.
Old 04-23-2012, 08:12 PM
tripn88's Avatar
tripn88
tripn88 is offline
What are your thoughts on using it as a primary brake light? If someone was to get rid of the turn/run/brake signals? Bright enough?
Old 04-23-2012, 09:42 PM
Mullenmc's Avatar
Mullenmc
Mullenmc is offline
It's wicked bright. So definitely replacing the running and brake lights. Not sure about the turn signals. That's like removing the reflectors, it's clean but not functional so that's your call.
Old 04-23-2012, 09:47 PM
tripn88's Avatar
tripn88
tripn88 is offline
Thanks for the response. The turn signals I want arent dual filament at least i think they arent, so this might fix my problem.
Old 04-23-2012, 11:23 PM
GodIsStevePerry
Nice. I was wondering how you got between the fender and the tire to run the wiring.
Old 04-24-2012, 08:35 AM
digitalhippie's Avatar
digitalhippie
digitalhippie is offline
I'm curious how the light mounts to the fender...
I have a 1200L and I'm looking for some tail lamp replacements... wondering if I could chop my fender then run this light.
Old 04-24-2012, 06:08 PM
Mullenmc's Avatar
Mullenmc
Mullenmc is offline
It's 3M. That **** doesn't move either. Wipe it down with alcohol and stick it. It also comes with wire clips that attach with 3M to run the harness up the middle of your fender.
Old 04-24-2012, 08:57 PM
digitalhippie
awesome, thx for the info
Quick Reply: Installed Flush Fender Light (Pics)
