My first torque wrench: Any suggestions?
Old 04-16-2012 | 03:05 PM
SportyPig's Avatar
SportyPig
You can do that ft/lbs to in/lbs conversion. But, if the specs call for 15 in/lbs...the precision of a ft/lbs wrench won't be accurate.
Old 04-16-2012 | 03:09 PM
enroper's Avatar
enroper
Well, I think I'm going to start off with a in/lbs wrench so I can change my tranny fluid. Thanks for the advice guys, suppose a visit to sears is in my future
Old 04-16-2012 | 03:27 PM
SamStone's Avatar
SamStone
Harbor Freight would be fine for maintenance. I haven't stripped any thing or had anything fall off yet. I wouldn't use them for anything inside of an engine.
Old 04-16-2012 | 03:30 PM
Jackie Paper's Avatar
Jackie Paper
Do not even think about torqueing these small replaceable covers. see search and see my spill there as to why not clutch cover leaking; helicoil?https://www.hdforums.com/forum/prima...3B+helicoil%3F
Old 04-16-2012 | 03:31 PM
enroper's Avatar
enroper
Why not? The manual says to...
Old 04-16-2012 | 03:33 PM
pointdogg48's Avatar
pointdogg48
i need one of these bad boys too. stripped so many bolts (like 3) overdoing it.
Old 04-16-2012 | 03:35 PM
Jackie Paper
added a short cut to my OPINION as to why not....https://www.hdforums.com/forum/prima...3B+helicoil%3F
Old 04-16-2012 | 04:00 PM
SportyPig's Avatar
SportyPig
84in/lbs is not much. To OP, one thing I would suggest, and I can't remember if it's in the service manual or not. Put some anti-seize on those bolts. If you don't, it won't matter how much torque to replace them with. It will take an act of GOD to get them out again.
Yes, that is the voice of experience you hear. And yes, acts of GOD have happened a few times in my garage. But, he's really busy and it takes a long time to get his attention.
Old 04-16-2012 | 04:05 PM
Kenny94945's Avatar
Kenny94945
Always buy good tools.
You'll have this torque wrench your entire life.
TW need to be calibrated ever so often.
You'll need two: a 1/4 drive for inch pounds and a 1/2 (with 3/8 adaptor) for 10 to 150 foot lbs
Sears is a good product at a good price.
Else Snap-On.
Old 04-16-2012 | 04:34 PM
cHarley's Avatar
cHarley
Also, torque wrenches are not very accurate near either end of their scale. You don't want to use a 10-150 ft/lb wrench if you're trying to torque 12 ft/lbs.
Quick Reply: My first torque wrench: Any suggestions?
