1200 Cracked Piston. Rebuild Kit Questions.
My friends 2004 1200 Sportster cracked a piston the other day. The bike only had 17,000 miles. We pulled the motor apart and both heads are marred badly. One piston is completely destroyed. He said he was at a stop sign and the bike just died.
My first question is could I just use a 883 to 1200 conversion kit to replace the sleeve and piston. Where is the best/cheapest place to get that and to get 2 heads?
My second question is what do we do about all the pieces of piston ring, piston, and head in the lower part of the motor?
www.nrhsperformance.com this is where I would start. 700 for a 1250 kit. And they make top quality parts.
Unfortunately, this repair is going to require a lot more than a top-end kit. The motor is going to have to come out of the bike and the cases split open in order to clean the debris out of the bottom-end and replace any damaged parts.
The OP may be better off looking around for a wrecked/totaled bike with a good donor motor.
If the motor is in that bad of shape from Detionation then your crank and lower bearings are proably all banged up. BUT if the bike was detionating that badly the bike should of barly ran. Only other time ive seen that is from someone runing Nitrous and it goes lean on the bottle. Time for a whole new crate motor
