Tuning necessary or not?
The vast majority of your riding is done in the closed loop mode, and this is where the bike will run at it's leanest. The info that the O2 sensors provide during this close loop mode is also used in an adaptive form when the bike is in open loop.
Why can't you tap into the sensor? They have AFR meters that are dedicated sensors.
So, it runs lean in any case, I might see if it runs too hot if the plug is melted or blistered right?
And if it runs too lean will the ECM tell me with error codes?
Is it definite that the 2012 O2 sensors will keep it from running too lean?
I don't mind lean (though I'd prefer fat to lean I think, it sounds less damaging), I just don't want my engine to get damaged.
there is no real point in reading plugs on a fuel injected bike....and yes the bike is running lean (hell it was from the factory) and now it is running leaner (this I know because of the popping)..get yourself a controller ....which ever one you like....the pcv is a good controler, but if you are not going to do any major work to the motor may be more than you need (if you get one I would go with the map from the folks you buy it from and skip the dyno) there are a bunch of other controlers out there some cost more some cost less, any of them will work for you, if you are real **** about gtting every single hp out of the bike get the more expensive ones, if not buy the cheaper ones .....on my new bike I have pcv and it works great, but I know I would be putting cams in it in the future so I needed more ability to modify the map, my last bike had a wiseco type controller and it worked great...the Xieds things will work just fine also...you just need to get more fuel in there and any of the controllers will do that ....
The AFR on your first dyno is pretty much what would be expected for a stock '07 & newer sportster- with or without any air cleaner or exhaust mods.
Adding a tuner or an enrichment devise will richen the AFR as desired. Just a matter of budget & personal preference as to which way to go.
Except for you Aklim, we all know that your way, with your particular tuner is the only right way. You've already played out that argument with me and a multitude of other people many times over. So, before you start again, I will agree with you- your way is the only right way. No need to beat that dead horse anymore.
The OP was unsure if is bike was lean- everyone told him it was and they were right, but if he wants to see for himself if the overall afr of the bike is too lean- look at the plugs.
I guess me any my automotive tuner didn't care for it so it was changed to a more satisfactory one to both of us.
Actually, I'd rather have the PowerVision instead of the SEPST but it was bought for me as a gift. When you can show me a different route that can cover all the same bases as either of the two, I'd be looking into it myself.
No- because too lean is how the factory ECM is set up t operate the bike most of the time unless you add a tuner or enrichment deivse- (back to the emissions and fuel economy thing again)
The bike will run smoother, cooler and happier with a richer afr than the factory lean setting. I personally think that the factory lean AFR isn't in the best, long term interest of the engine.
Every 2012 sportster rolled off the assembly line running lean. No need to hook anything up to anything to know that. Want a quick, easy, cheap way to "see" it, pull a plug. Want more details, and don't mind spending the extra money, to find out the same thing, then have it dyno'ed. If all you are trying to do is confirm that it is running lean, I'm not sure a dyno chart is "better". But since you say it is, I'll agree.
