EFI Stage 1 Tuning using HD Race Fueler (long)
Old 12-31-2006 | 01:08 AM
rharrison's Avatar
rharrison
Default RE: EFI Stage 1 Tuning using HD Race Fueler (long)
Congratulation on taking the plunge. I will be glad to have a "serfing" buddy I appreciated your questions and will include them in an edited compilation of my posts. Once I have dyno results, I will add that info as well. I will be happy to attempt to take some pictures on how I mounted my SERF. I think come this spring these posts will be in demand as the EFI bikes really get on the highways! Hopefully we can all help one-another in the fine-tuning of our EFI Sporties.
Old 10-07-2008 | 01:18 PM
cbrum2622's Avatar
cbrum2622
Stage III
Default HD Race Fueler Tuning.
Hey, very helpful info here. You left off at tuning "Dial 1". What about the other dials?
Old 08-05-2020 | 03:13 AM
Josh hurst's Avatar
Josh hurst
Stage IV
Originally Posted by rharrison
I have experienced Stage 1 success with my EFI sporty using the Screamin’ Eagle Race Fueler (HD part 32173-07) or SERF. This post is to help first time users set up their SERF quickly.
First, why a SERF and not a remap? The cost is about the same, but the SERF allows you to “tune” the bike to your needs and modifications. You can lean out 10% or richen up to 40% for each rpm range. You can also change the crossover points and change the “accelerator pump” 0-100%. It is like having a parts-bin full of carb jets, but takes only seconds to change settings.
Downsides? The instructions for installation are OK, but my dealer was worthless when it came to setting this thing up. However, with the help of the Big Twin guys on another forum, I have dialed-in the SERF and am very pleased with the results. I hope my findings will encourage some additional tuning dialogue for those using a SERF or similar devices, such as the FuelPak.
Installation: The unit is plug into the existing wiring harness. Install the SERF (about the size of a lighter) on the battery bracket behind the battery cover using the enclosed Velcro. It fits perfect. Run a ground wire under the seat (the ground point to use is obvious). Run the wires in such a way as to ensure they do not touch the engine. The kit includes the ties to keep the installation neat and OEM appearing. The great thing about this kit is that it can be removed and no-one will know it was ever there!
Tuning: The dials (potentiometers or pots) on the SERF are oriented as follows.
| 1 |____| 2 |____| 3 |____
Red LED Yellow LED Green LED
| 4 |____| 5 |____| 6 |____
R = Red LED Low rpm range Y = Yellow LED Mid rpm range G = Green LED High rpm range
What each dial, or pot, does:
1 Low rpm range fuel adjuster ______ -10% to +40% fuel correction
2 Mid rpm range fuel adjuster ______ -10% to +40% fuel correction
3 High rpm range fuel adjuster _____ -10% to +40% fuel correction
4 Low to Mid rpm cutover range _____ 900 to 3500 rpm
5 Mid to High rpm cutover range ____ 4500 to 7100 rpm
6 Accelerator fuel enrichment _______ 0 to 100%
The dials are marked 0 to 10 0 = Fully Anti-Clockwise position on all dials 10 = Fully Clockwise position on all dials. For example Position 2 on Dials 1, 2 & 3 roughly equates to no fuel correction. My unit was factory set from 0 to 2, meaning the bike ran poorly before changing the settings. Do not worry about that, and once installed, go for a ride to warm the bike up to full operating temperature. Now, take off the battery cover, open the SERF using a very small Phillips screwdriver (the same one you will be using to adjust the pots) and let the fun begin.
Dial #____Position
Dial 1 ___ 3
Dial 2 ___ 3
Dial 3 ___ 4
Dial 4 ___ 3 - (Low to Mid rpm needs to be set at around 2000 rpm which is about setting 3) \
Dial 5 ___ 0 - (Mid to High rpm needs to be set to 4500 rpm which is 0 on the dial)
Dial 6 ___ 5
Now, Take it for a short ride. Better, eh? Actually, it should be much better. Now, for the REAL fun. Fine Tuning.
Dial 1: Start the engine up and slowly increase the rpm until the red led goes out (about 2000rpm) and the yellow led comes on then bring it down a bit until the led's swap back over and we have the red one lit again. You need to hold this rpm really steady (now you can finally use that throttle lock on the handle bar). Now very slowly increase dial 1 (clockwise), the engine should start to speed up (if the yellow led comes on then set the throttle back a little so we are back on red). You will get to a point where the rpm no longer rises and then you can turn the dial back down to a point where the rpm just starts to reduce. On mine, this was about setting 4.5
Dial
on the 1 2 3
4 5 6
what side is the front of bike or what way is tuner?
Ajmccarl
07-27-2016 12:50 AM
Gee
04-12-2013 02:20 PM
reggin
01-08-2010 03:03 PM
rharrison
04-04-2008 08:31 AM
HDF Tech
03-08-2006 04:44 PM
