Big City Thunder QQ Monster Baffles
Real easy to make on your own if you are into that sort of thing, if you are talking about the standard baffle and not the quiet baffle. All it is is a step down step up pipe with a lolipop in it. Get a bolt and a large washer or a thumb screw, put in it and you are set. I think they are way overpriced for what they are. The pipe they come does step down a bit to restrict flow which you could easily buy and have a muffler shop take a smaller outer diameter pipe and flare the ends to the inner diameter of your short shots then put the lolipop in your self then put in your pipe.
tmac00333
04-13-2015 04:50 PM
